Topic: Video and Karaoke not playing well.
djsalviPRO InfinityMember since 2007
Hello, my video and karaoke files were playing just fine on vdj 7. However something strange is happening in VDJ 8. Ex. Videos play but black out after a few minutes. As for the karaoke files, samething, and some don't even display.
VDJ latest build
Win. 7
Dell xps 1710
12 meg ram
Dedicaded video card 4 ram
I'm sure it has something to do with my configuration.
Your advice will be greatly appreciated. Thx in advance!
geposted Sat 08 Nov 14 @ 8:51 am
looked up the specs for your laptop
Processor type Intel Core™ Solo processor or Intel Core Duo processor
L1 cache 64 KB
L2 cache 2 MB
External bus frequency (front side bus) 533 MHz or 667 MHz
Maximum memory 4 GB (via 2 x 2 GB SODIMM DDR-II modules)
Video controller: NVIDIA GeForce Go 7900 GTX
Video type 256-bit hardware accelerated
Data bus
PCI Express
Video memory
256 MB or 512 MB
what dedicated video card do you have?
pretty sure you need 1gb ram for video to have any success with video playback ??
if you happen to have the 256 MB video option I'm sure that's the issue.
geposted Sun 09 Nov 14 @ 11:01 am
ok so i was wrong
-ATI™ or NVIDIA® video card w/256MB of
Dedicated DDR3 RAM
-Video card must support dual
-screen output
Maybe you just need to optimize your PC good luck.
this might help - www.numark.com/static/dj-computer-optimization and www.youtube.com/watch?v=P7awctTsK34
geposted Sun 09 Nov 14 @ 11:18 am
Thank you for the suggestions. I will give it a try.
geposted Sun 09 Nov 14 @ 4:38 pm
