Topic: different bugs in vdj8
automix prelisten preview not workin
my library folder specially the compatible song in (key) folder doesn't work properly it doesn't gives live feedback when i change songs and pressing on it during mixing or loading a new song
a skin called controller for dennyo the eject function short cut doesn't work,the browser button can't mapp it to my keyboard short cut
the pre listen headphone stops when i press the same song again i have to press another track to make it work wish u do it like the vdj 7 behavior
all this is happening in vdj8 mac version i use mac book pro OS X 10.10
any new bugs will be informed
geposted Wed 12 Nov 14 @ 11:18 am
also can't move or drag tracks from sidelist to auto automix icon(not from sidelist in the horizontal but from the sidelist in the vertical side )
geposted Wed 12 Nov 14 @ 11:21 am
I use my controller mixer to kill the bass knob in vdj 8 but it is not killed in my headphone only outside in da speakers
geposted Wed 12 Nov 14 @ 7:51 pm
I don't use a Mac, so can't address those issues, but isn't there a "equalizerInHeadphones" setting that you can adjust?
geposted Wed 12 Nov 14 @ 10:58 pm
