Hi looking on using a controller with my surface pro 3 using virtual dj
So far for the price the pioneer ddj sb looks fine
My only concern is it is missing the gain/trim controls on the for mixer
Has any one else used this and seen this as a problem , I like having gain/trim as some songs R lower than other etc
If not I might have to wait and buy the ddj sx
geposted Wed 12 Nov 14 @ 2:33 pm
set the auto gain in VDJ to auto and then for minor tweaks you can just use the line faders?
geposted Wed 12 Nov 14 @ 3:00 pm
+1
I will add that you should tweak the settin for a few DB lower the default to stay out of the limiter.
My setting for ZeroDB is 0.8 and autoGain is set to auto
I have plenty of head room with this setting, the auto gain scanning works very well for me
My controller is a Numark Mixtrack Pro, wich is also without gain knobs.
geposted Wed 12 Nov 14 @ 4:18 pm
i have 2 ddj sb, like they said set to auto, you'll be fine
geposted Thu 13 Nov 14 @ 4:49 pm
