hi guys...
i found a small grafic bug while i was remixing a track.
it happend while you a recording and you accidently drag the recording track, ( that i inadvertently not stopped the recording ) into a selected deck .
A small icon window pops up permanently, that will not pop off/out, when you drag a different track.
I had no performance/quality problems during the set.
May you can remove the bug on the next update.
Brgds
Brgds
geposted Thu 13 Nov 14 @ 4:20 am
o, i see it must be a skin problem, because i recievie an ususal Error on the decks with the original skin....
I have to inform Dennyo to resolve it, thanks btw for the great work !
geposted Thu 13 Nov 14 @ 4:29 am
