Hellow guys,
I'm still using VDJ Full Pro 7 for the moment because i experience to many troubles in VDJ 8.
First: its the tabs above the browser that doesn't work anymore i use normally a TK filter which is gone in VDJ 8 (Wtf :O) to make it sound like on a DJM-700. But i can't click on the tabs anymore (records,effects,etc...). My Reloop beatmix doesn't give me the option to modify the Tk filter like on VDJ7. Is there a .dll for the TK Filter for VDJ 8 ?
AUTO GAIN never works no matter what setting i set
Is it because i use the Reloop Skin ?
Second: When i start record i can't choose 320 kbps like before, is it random ?
Thanks for more information and the helpful comments. I want to start ASAP because VDJ8 looks more smooth and the mechanics works better.
Edit: nvm i found for the effects tab when u click on the setting it appears down and stays. :D Just don't find the TK filter. :s
geposted Thu 13 Nov 14 @ 1:58 pm
Pulled from page 87 of the manual, "A different quality can be selected from the option recordQuality in Advanced Options under the group Record (low=128Kbs, mid=192Kbs, high=320Kbs)."
The TK Filter is not available in ver 8 yet.
geposted Thu 13 Nov 14 @ 2:21 pm
The Tabs issue is because V8 doesn't have FX/Sampler pages anymore. Use a V8 skin.
geposted Thu 13 Nov 14 @ 2:23 pm
They could be made to do something, but it'd mean a skin mod.
It would've been good to have a config option for "VDJ 7 compatibility mode" or something, so people don't get too confused.
geposted Thu 13 Nov 14 @ 2:29 pm
Thanks this helped me out for one thing already ;-)
What about the auto gain that? Everything goes red no matter what i have to put them down very low ? Does it affect or not if i record in red ?
geposted Thu 13 Nov 14 @ 4:01 pm
Is ok i used VDJ8 and sorted things out. The basic filter is adjustable if u put good setting its like TK filter. ;-) 214 khz and 80 resonance u have a good filtered bass but still kicking.
For the quality output for recordings its ok in advanced options.
For the tabs u click on the setting of an effect and he add himself down in the browser and u can adjust everything with your console and see the changes.
Thanks anyway and this is a good update.
Only problem is still this gain.
geposted Thu 13 Nov 14 @ 4:16 pm
Moving from 7 to 8 everything to be rescanned (it's unavoidable), perhaps that's the source of your Autogain problem.
geposted Thu 13 Nov 14 @ 4:49 pm
Nope, he still doesn't autogain for a unknown reason.
geposted Mon 17 Nov 14 @ 1:07 am
How about controllerTakeOverMode? if you have that set to instant then perhaps autogain won't work (possibly I'm not certain)
geposted Mon 17 Nov 14 @ 1:23 am
Hmm may check this out. Its possible its my Reloop controller doing that. Thanks i come back to you later
geposted Mon 17 Nov 14 @ 9:21 am
