hi,
in my opinion the WAVEFORM LAYOUT (defaultwave 2 or 4 decks) visibility is worse than in 7.4 etc.
when you have deck 1 playing (blue wave) and you select deck 2 (red wave) or 3 or 4 etc. , I think the focused track is too transparent for easy navigation and visual feedback.
I think when you select a deck the waveform should be more distinct and less transparent, because it is the deck that you will be cueing and mixing in. please show me the setting or please add an option for focussed deck transparency !! That would be great!
geposted Fri 14 Nov 14 @ 8:29 am
