Topic: Browser sort (Keep sort order)
When applying the following settings in Virtual DJ 8
keepSortOrder = no (meaning that when you apply a sort order in a particular folder and you change back to another folder it should not keep that sort an revert to original or default or whatever)
This is not actually happening and the sort is only "forgotten" when you close the program and open another instance. Please help.
geposted Fri 14 Nov 14 @ 2:16 pm
+1
keepSortOrder does not work as might be expected
