1. Will Virtual DJ 8 remember my cue points, tag editing and BPM edits from 7.4 if I upgrade?
2. Will 8 remember my shortcut keys on my laptop (Example: #1 Play Sample).
These are really the only things holding me back from VDJ 8. My cues, tags & BPMs would take months to re do seriously!
Thanks for any response in advance!
geposted Sun 16 Nov 14 @ 3:45 pm
All of the above should be brought in fine. I would make a backup of your VDJ folder and your library files (which is something you should do regularly). After the back up, give it a try. You can have both installed at the same time.
geposted Sun 16 Nov 14 @ 11:52 pm
Some script for mapping needs rewriting, which scripts you'll have to find out yourself.
Loop roll in V7 is now know as a loop in slip_mode
Sampler scripting has changed a bit
erm there might be other bits that I'm forgetting, but most of my mapping(s) worked without editing.
geposted Mon 17 Nov 14 @ 12:18 am
