Topic: Video Transition not run all
Is there a way that I can remove some Video Transitions?
Example: Glass, Droplets and some more produce only a black image area during the transition.
If I have the options "Video Random Transition" to yes, the screen is black with some transitions.
I work with MAC Build 2048.868
Many thanks.
geposted Tue 18 Nov 14 @ 2:51 am
Haui70PRO InfinitySenior staffMember since 2008
Please delete ALL non native transitions from plugin folder side.
Now please try it again - Can you notice the problem again?
If yes, please let me know.
Of no, please download again the additional transition from Addon side.
Then please try it again, do they work now?
If you still notice a problem, please write here the transition effects which will cause the problem.
geposted Tue 18 Nov 14 @ 3:45 am
There are no plugins in Plugins64 / Video Transitions folder.
There are 0 files available.
I can not delete.
I do not even intsalliert, who were all in VDJ8 during installation
The following are not running:
Cloud disslove
color swap
drain light
drain
Droplets
extreme Cut
Glass
Luma Key
Splodge
Warp
Warp speed
Run the following:
Slide
Shatter
sequences
scrolling slice
Satellite boom
Satellite
Pixelatae
none
Grid
Flat Cube
bland
Cube
Doors
flip
flip 3D
zoom
Wipe
window
window double
Strobo
I also find no path as me Jkovski wrote: This is the path for VirtualDJ 8 - I guess there are old v7 plugins on the computer. As I said, I know unfortunately path from the head not.
Edit: Look here: http://www.virtualdj.com/wiki/Mac%20Install%20Effect.html
Should be here to find:
MacintoshHD -> Users -> YOUR USER NAME -> Library -> VirtualDJ -> Plugins -> Video Transition
Wo kann ich diese sonst entfernen?
How i can delete this?
geposted Tue 18 Nov 14 @ 5:48 am
Lets move over to the German forum. Should be much easier.
geposted Tue 18 Nov 14 @ 6:02 am
Native effects can not be uninstalled.
Glass transition is working here. Which version of Mac OS X do you use, and which video card?
geposted Tue 18 Nov 14 @ 6:11 am
I work with MAC and 2 both are not going
OS X 10.9.5 (13F34)
NVIDIA GeForce GT 650M 512 MB
OS X 10.9.5 (13F34)
Nivida GeForce GT 330M 512MB
[Edited by Heiko] He explained that he owns 2 licenses running on 4 Macs in total. Same problem on all 4 he said.
geposted Tue 18 Nov 14 @ 7:08 am
Danke dir
geposted Tue 18 Nov 14 @ 7:18 am
