Updated to latest version of VDJ V8 build 20148.868 using a Pioneer DDJErgo K
Before the update, my MIX (cue/master) knob worked fine on the controller.
I could hear the cue track and turn the Mix knob to hear/not hear the current playing track/cue track.
Since the update, this knob has stopped working on the controller.
Anyone else having this issue?
geposted Tue 18 Nov 14 @ 4:02 pm
I fixed it by remapping it....not sure why I had to, but anyway, all fixed ignore the above :)
geposted Tue 18 Nov 14 @ 4:21 pm
mine is broke as well same controller
geposted Tue 18 Nov 14 @ 5:13 pm
Indeed there was a typo in the mapping files. Will be fixed in builds ending at .875 (or higher).
geposted Tue 18 Nov 14 @ 10:07 pm
Thank you for letting us know :) Appreciated.
geposted Wed 19 Nov 14 @ 1:44 am
