Topic: BPM & Key Too Close Together!
Is there anyway you can give song BPM & Key a little more space apart in the browser? They are really scrunched together!
Thanks!
geposted Wed 19 Nov 14 @ 11:17 pm
frd1963PRO InfinityMember since 2004
I am not as familiar with VDJ8, but with VDJ7, you can grab the header separators and slide them left and right. I assume you can do the same in VDJ8, at least I hope so!
geposted Thu 20 Nov 14 @ 12:00 am
Yes you can.
geposted Thu 20 Nov 14 @ 3:28 am
You can move the separators like in VDJ 7 but BPM & Key still stay on top of each other.
geposted Thu 20 Nov 14 @ 2:50 pm
FruitPRO InfinityMember since 2003
Reorder them.
geposted Thu 20 Nov 14 @ 6:10 pm
Yes, you could re-order them but why do you have to? You can make as big of a separation as you want.
geposted Fri 21 Nov 14 @ 12:40 am
But the incrimined field is "key", not "harmonic"...
The "key" field is left aligned.
geposted Fri 21 Nov 14 @ 1:05 pm
