Topic: Pioneer DDJ Ergo K Mapping
geemixPRO InfinityMember since 2006
I have been unable to map my Headphone Vol button to skins (currently Fruit Skin) at all.
Does anyone have the same issue and any fixed mapping for this knob? Thanks.
The knob works, turning volume up/down...a soes the Volume knob on the skin. Just cannot get them to map!
Same applies to Master Volume! Cannot map it either!
geposted Fri 21 Nov 14 @ 2:12 pm
A wild guess, do you have anything Faked?
geposted Fri 21 Nov 14 @ 2:42 pm
Headphones Volume, and Master Volume knobs of the Ergo dont send any MIDI, so they are not mapped. Those work in a hardware way.
geposted Fri 21 Nov 14 @ 4:13 pm
AsTheDJPRO InfinityMember since 2008
Try mapping it in VDj-7 1st then reopen 8,there is a lot of custom mapping VDj-8 can't set up the way I need like Vdj-7,but they share the same mappin in PRO ONLY.
geposted Sat 22 Nov 14 @ 10:21 am
loco not sure what you mean by faked, I have purchased VDJ and Ergo console...neither are fake.
I couldn't get them to map in VDJ7 either. bit weird why they can't be tho!
geposted Sat 22 Nov 14 @ 3:42 pm
