Firstly only just started using the programme so I'm pretty new to it. But halfway through the night while playing my playlist on automix one song started but then it was if the same song was playing at the same time but slightly behind. Only one deck was being used so I got confused and had to close the programme and restart which seemed to solve it. So just wondering if anyone knows what the problem may be and how I get round it next time.
Cheers
Cheers
geposted Sat 22 Nov 14 @ 7:18 am
try have a 2nd song ready in the empty deck to play and fade auto mix song off then turn it off eject the song from auto mix & have the next one ready when the song in the 2nd deck stop.No need to shut down and reopen VDj or you can stay and just fade in/out songs your self if need it.
geposted Mon 24 Nov 14 @ 10:41 am
Did you happen to have the same song selected in the browser? Could it have been prelisten?
geposted Fri 28 Nov 14 @ 5:51 am
Thanks for the advice I will make sure I have another song ready next time, luckily I got somebody up to sing on the karaoke which gave me time to shut down and restart. I didnt have any other songs selected in browser. It just suddenly did it without me doing anything might of just been my laptop playing up, now panicking incase it does again though.
geposted Fri 28 Nov 14 @ 5:55 pm
You do know that you're not permitted to use the Home version professionally (paying gigs)?
geposted Fri 28 Nov 14 @ 5:58 pm
