Topic: DDJ-SX jogwheel settings
DJ KozPRO InfinityMember since 2007
Anyone care to share their jogwheel settings for their DDJ-SX in 8 if they are working right for you?
My jogwheels don't feel right at all.
geposted Sun 23 Nov 14 @ 10:23 pm
Does the SX not have a knob on the front panel to adjust the jog sensitivity?
geposted Mon 24 Nov 14 @ 1:49 am
Yes tried that. Looking for what people have in their settings for jogwheels.
geposted Mon 24 Nov 14 @ 7:22 am
No one here has settings they are happy with for jogwheels on the DDJ-SX??????????????????????
geposted Mon 24 Nov 14 @ 5:00 pm
no one??????
geposted Mon 24 Nov 14 @ 10:05 pm
I just use the defaut settings - no need to change anything.
geposted Tue 25 Nov 14 @ 12:27 am
Perhaps, it would be easier, if you could provide more info or describe your issue in detail. Keep in mind this thread is to report bugs, so if there is something that needs to be fixed, its OK that you posted here.
geposted Tue 25 Nov 14 @ 6:15 am
Basically when I'm moving the wheels to cue there is a huge lag. Especially when I stop moving them.
geposted Tue 25 Nov 14 @ 7:20 am
DDJ-SX (and other devices from the DDJ series) have a firmware "protection" on the jogs that the unit will NOT report "small" movements if you don't touch the top of the platter first, or if you don't perform a "big" movement first.
There's nothing VirtualDj can do about this since it's embedded on the device's firmware to avoid accidental movements from vibrations e.t.c.
Is this what you're talking about ?
geposted Tue 25 Nov 14 @ 9:25 am
The song keeps moving after letting go of the wheels... cueing forward or backward. The faster i do it.. the more it does it.
geposted Tue 25 Nov 14 @ 9:34 am
I'll spin the jogwheel to cue and when I let go the white lines in the wheel and the wheel on the skin and waveform keep moving.
geposted Tue 25 Nov 14 @ 9:43 am
In that case try the setting TouchweelBackspin to No
geposted Tue 25 Nov 14 @ 9:48 am
Will I lose sound when i bring the wheel back or the backspin sound when i spin the platter back ... with or without vinyl mode on?
geposted Tue 25 Nov 14 @ 9:52 am
