any way to split the Settings XML into a LOCAL version for Sound card and controller setting and another for performance/personal so I can take MY personal options with me so the software behaves the way I want to without changing the settings of someone else's?
like the way the EQ resets on load, the CUE settings, sidelist behavior, pitch range etc.... those are a personal thing and will vary from DJ to DJ. The ability to make those settings once and take them with me would be a great feature.
I think it was mentioned in another post, to have those settings cloud based and transfer with the account when you log in, but in order to make that feasible the local(PC/MAC) settings would have to be split from the personal part of the XML.
EDIT:
I think skins should be part of that too, and kept with the personal setting and able to easily travel with me without having to change the entire setup of another system/setup to use.
EDIT:
geposted Mon 24 Nov 14 @ 5:58 am
