Topic: feedback problem
leneerPRO InfinityModeratorMember since 2014
Operate is Very complicated,Other software is Very simple;
Many people told me often appear noise, after a judgment is a computer hardware (The CPU/RAM less than 2GB) problem,
Can't two music use onekey to mixes like VDJ7;
Won't be set shortcut keys,Multiple deckc can't separate to operation,Operating one deck other deck will be the same operation;
They are very need real disk drive skin;
Recording is very trival, if switch other skin only recorded in setting interface;
Pioneer DDJ-SR Low Mid High knob not work,but serato is perfact,Can be synchronous display, but have no effect;
the effect compatibility is very poor;
geposted Tue 25 Nov 14 @ 10:41 am
Is English your native language, or are you using a translator? This is very hard to understand.
geposted Tue 25 Nov 14 @ 2:19 pm
