Hi
in VDJ Pro 7, under the "Play List Tab", there was a little helpful menu that allowed you to
Save, Delete, Shuffle, Del_Duplicate Etc,
Anyone know where We can find that menu or gain access to it?
thanks for any help.
geposted Fri 28 Nov 14 @ 5:12 am
when you have the automix tab open the small button in the top right window brings up playlist options.
or you could assign a keyboard shortcut with 'playlist_options'
hope this helps
pete
hope this helps
pete
geposted Fri 28 Nov 14 @ 5:23 am
hi Pete, thanks a bunch for the reply
not following m8
not following m8
geposted Fri 28 Nov 14 @ 5:51 am
That's the 'info' tab!
'automix' is in the sideview (left of the info tab). Select the third icon at the bottom (the crossed arrows).
See page 42 of the manual....
geposted Fri 28 Nov 14 @ 6:28 am
ahhh got it, thanks so much Pete.
geposted Fri 28 Nov 14 @ 2:01 pm
