Forum: Beta Builds Regression Bugs
Topic: BUILD 2069
-Fix regression on mac causing crash when thread exits before startThread finished
-get_bpm shows local bpm
-Fix crash on windows with some midi devices sending sysex messages to unprepared buffer
geposted Fri 28 Nov 14 @ 12:13 pm
Does that mean you can have a "live" BPM readout instead of the scanned one in the DB?
I think it's instances where you've regrided the CBG over a tempo change. :-(
FOR the last 2 update it been doing this TIMECODE VINYL
With this update when i hold the platter on the turntable and get ready to mix in the songs it jumps in the beginning of the track and lose sticker drift when it jumps i am using SL3 BOX windows 8 / I7 16 OF RAM and i did a fresh install to .
And still the timecode vinyl off and on button still not working right when i turn it on and off on the software it make the track jump.
when the fix freezing interface!!!
Working 100% for me. No screen tearing & freezing. CPU very low
1. Virtual Folders cant be renamed
2. Virtual Folders cant be moved inside Favorits as shown in pichture. It will be moved in the last order, not as aspected and shown by the marker!
in my case its not possible to move the virtual folder between CLUBSOUND and CHILL ELECTRO. VDJ put it as as child of Clubsound
Only way ist to edit the "order" file
I confirmed it can not rename a folder in a red virtualfolder fovoritefolder yellow folder.
Quote :
That's because you have a virtualdj crack installed.
Try to remove all cracks and use a legal installation of VirtualDJ, and everything will work without freezing.
[quote=]when the fix freezing interface!!![/quote]
Please try to be fair,dont waste your time,when you already know you have crack soft,so please for crakerboys dont excpect the team gonna help,be serious !!!!!
