Hello,
I noticed the browser button on this isn't setup correctly in the default configuration. At the moment the only way to fix this is to change it to (browser_window "folders,songs") and then it should work like it should. The only problem with this though is that you can't open up folders to see the subfolders inside. The solution would be to open those before you use the controller. I hope this helps!
geposted Fri 28 Nov 14 @ 7:37 pm
