As the snip below shows, v8 just idling, resized to a smaller window suddenly "zoomed in" like this...
any ideas why?? is it a regression bug (i hope it is)
geposted Fri 28 Nov 14 @ 8:47 pm
close v8 and re-open.. back to normal size..
geposted Fri 28 Nov 14 @ 8:49 pm
I can't get it to happen here (I switched to the same skin too).
Windows 7 Home Premium 32 bit SP1
AMD Radeon HD6670
AMD Radeon HD6670
geposted Sat 29 Nov 14 @ 6:21 am
its not skin specific and its an intermittent fault, as in, ive only ever seen it very rarely.
geposted Sat 29 Nov 14 @ 9:34 am
I would be inclined to think it's an issue with your graphics card.
Have you tried it on another computer?
geposted Sat 29 Nov 14 @ 9:43 am
is it possible some how you have click a hotkey that enable a zoom utility i know windows has a built in one.
geposted Sat 29 Nov 14 @ 10:10 am
the windows zoom utility is activated by holding the windows key and then pressing '+'. to turn it off hold the windows key and press 'esc'.
if it was this, then all software on his system would be magnified, so might not be the windows magnifier, but worth a try anyway.
pete
pete
geposted Sat 29 Nov 14 @ 10:21 am
