scratchwave drift bug :
bug issue when using hotcues/cue, backspins, or more heavy scratching, scratchwave skips a bit , and audio gets off sync with waves on-screen (mac osx) (can replicate this bug using only the mouse, hold the scratchwave and jump between hotcues to check drift)
scratchwave drift happens with Pitch Quality 1 or 2, does not happen in 0 (zero), -1 or -2.
vinyl sticker drifts with pitch quality 0, after a few revolutions (+5 or more); no sticker drift with pitch qua. -2 very small drifts on -1
tested on mac ( osx 10.7 / windows 7 )
thank you
thank you
geposted Sun 30 Nov 14 @ 4:45 pm
Yes scratch wave drift and audio gets off sync with waves on-screen
that need fixing I'm using windows 7
i have Noticed the waves not going very smoothly that need fixing to !
geposted Wed 10 Dec 14 @ 3:19 pm
new build 2090 did not fix the wavedrift on pitch qua 1 or 2
geposted Wed 17 Dec 14 @ 7:17 am
