Topic: hold to play
djjeckyPRO InfinityMember since 2011
Hi all. Quick question. is there anyway to have hold to play option on the cue points?
geposted Wed 03 Dec 14 @ 7:03 am
dcomoPRO InfinityMember since 2012
I think you can map a button to this. I recall someone at some time requesting a similar feature.
geposted Wed 03 Dec 14 @ 11:23 am
I think that would be the while_pressed command.
Adding that to the cue buttons already on the skin would mean editing the skin XML, but you could do it with custom buttons.
geposted Wed 03 Dec 14 @ 11:37 am
pause ? cue x ? cue x while_pressed : cue x : cue x
Try that in place of your hotcue mappings X = cue number.
geposted Wed 03 Dec 14 @ 2:53 pm
Ok cool. Thanks. Ill try it tomorrow
geposted Wed 03 Dec 14 @ 2:55 pm
That one only does the hold to play when paused, is that what you're after?
geposted Wed 03 Dec 14 @ 3:01 pm
im looking for while playing
geposted Thu 04 Dec 14 @ 7:14 am
not exactly sure what you re after...Try this too..
replace hot_cue x with cue_play x
If pressed for more than 2sec and then release, the track will continue playing. If released earlier, it will go back to the cue point
You can also specify the "delay" using .. cue_play x 3000ms
geposted Thu 04 Dec 14 @ 8:21 am
I'm a bit confused, explain exactly what you want to happen
I'm playing a track and when I press the button This happens and when I stop pressing the button this happens
try
hotcue X while_pressed
geposted Fri 05 Dec 14 @ 7:54 am
