Hello everybody,
Since the update on Thursday my Virtual DJ 8 does not work properly on my Mac.
Problem is that after about 1 to 2 hours it constantly crashes and closes the program.
So I am forced back on Virtual DJ 7 access back. Can someone help me or has the same problem ???
Greeting Niklas
Greeting Niklas
geposted Mon 08 Dec 14 @ 8:22 am
Myself and another one of the guys in my company are having the same issue. It crashed on his computer twice on Saturday so he switched to VDJ7. It happened to me once on Saturday so I switched to VDJ7. I tried VDJ8 on Sunday and after about an hour it crashed and shut down again so I finished the event with VDJ7. Please help.
geposted Mon 08 Dec 14 @ 3:45 pm
Crashed three times on me at a gig on Saturday night! Also the display froze once, but the music kept going (I just mixed into my iPhone and then restarted VDJ).
Seemed to happen when I was either a) loading a song from Content Unlimited or b) running up a loop and moving the jogwheel.
CPU level was no higher than it normally is.
Please tell me this issue is being worked on. I have two gigs this weekend and reliability is paramount!
Mid-2010 MBP - 2.4ghz Core2Duo - 4gb Ram - Mountain Lion
geposted Mon 08 Dec 14 @ 6:35 pm
+1 ,
random crashes backspinning on SCS1d and VCI-100, osx 10.7
build 2069 does not crash
geposted Tue 09 Dec 14 @ 5:10 am
FYI, you can download build 2069 from http://virtualdj.com/download/virtualdj8/mac/2069
Could you confirm if that one does not crash?
Also, you are all using OS X 10.9 or earlier?
geposted Tue 09 Dec 14 @ 6:41 am
mid 2010 macbook pro Im on 10.9.2 2073.891 no crashes here cpu seems about 5- 10% higher than normal
geposted Tue 09 Dec 14 @ 9:51 am
MacBook Pro 2,2 I7.... Yousemite 10.10.1.... Crash
geposted Tue 09 Dec 14 @ 5:08 pm
mbp 15 i7 2.2 10.10 also crash after 1 hour
geposted Tue 09 Dec 14 @ 7:36 pm
If an update until the weekend that my virtual dj 8 come back to work?
geposted Tue 09 Dec 14 @ 10:42 pm
Tried to downgrade to that version in the reply... also crashes
tried with ddj-sx and ddj-sx2
os x 10.7.5
os x 10.7.5
geposted Wed 10 Dec 14 @ 1:35 am
CRASHING LIKE CRAZY!!! WHEN USING BACKSPIN EFFECT WHILE 2 SONGS PLAYING!!! HEY ANYONE FED UP WITH VDJ8 YET???????????????? I KNOW YOUR OUT THERE!!!!! READY TO DUMP VDJ CAN'T TAKE THIS ANYMORE...AND NOR SHOULD YOU!!!
geposted Wed 10 Dec 14 @ 4:48 pm
mac osx 10.9.5.............after the latest update (2073 build) it crashed while in broadcast mode....touched the jogwheel and it crashed.....after that it started crashing all over the place and not only while broadcasting......went back to 2069 and it crashed again while broadcasting but it hasn't crashed "yet" while just playing / mixing........any ideas gang?
geposted Wed 10 Dec 14 @ 6:33 pm
Please try with the latest beta build 2087
geposted Wed 10 Dec 14 @ 7:49 pm
how djdad? the same way i went back to build 2069 from 2073?
geposted Wed 10 Dec 14 @ 8:07 pm
To receive the beta builds to all of your computers, enable the "get beta builds" option from your Account.
To receive the beta builds only to a specific computer, enable the setting getBetabuilds from the Advanced Options of VirtualDJ
geposted Wed 10 Dec 14 @ 9:22 pm
djdad i did some poking around before i noticed your reply.....i downloaded the 2087 build (i am not sure but i think it's not the beta version because i hadn't enabled the option in my account you mentioned)...at the top of the settings page it states mac build 2087....anyway i tested the programme for three hours without experiencing any hick-ups................of course i haven't tested it in broadcast mode where it has been crashing......i really don't feel comfortable 'cause i got a gig coming up......stay with mac 2087 if it continues to hold out?go to beta?.....use vdj7 pro?.....thanks again for your help
geposted Thu 11 Dec 14 @ 4:13 am
Actual 2087 is the beta version and only available for user which have enabled get beta under MyAccount side or inside VDJ Config - Option.
http://www.virtualdj.com/forums/76/Beta_Builds_Regression_Bugs.html
geposted Fri 12 Dec 14 @ 1:53 am
http://www.virtualdj.com/forums/196393/VirtualDJ_8_bug-report_Forum/VDJ8_crash_on_mac.html
Worked on it last night with ddj-sx2 and i didn't found any bugs
geposted Sat 13 Dec 14 @ 4:02 am
I had a gig today and I had "dead air" for a good minute. I did not have this issue with my last laptop (latitude e 6400) Kind of makes regret upgrading to a macbook pro with all the issues! I tried everything here and I still need to "force quit." My screen freezes when I use content unlimited.
geposted Sun 14 Dec 14 @ 3:03 am
Crashed twice during my Friday night gig, so I had to fire up VDJ7 for Saturday night. Not pleased....
geposted Sun 14 Dec 14 @ 3:52 pm
