I changed the setting with the SZ and the SX2 and it Doesn't working, in the SZ it Doesn't work at all in the SX2 Everything works except the waveforms There is sound but they are not moving, Only if I go back to default 3124 they start to move.
geposted Mon 08 Dec 14 @ 7:22 pm
the mixer order is actually a skin option. It changes the order of the mixer channels in the default 4 decks skin and not in the controller.
Some controllers offer dual mixer channel support, but most of them do not. They follow the order that the manufacture has set as default based on the silkscreen of the unit.
In order to change the channel mixer order for a unit that doesnt support dual mixer order in the native mapping, you will have to change the mapping of eacj mixer Key to something like ..
action_deck 1 ? deck 2 volume : action_deck 2 ? deck 3 volume : action_deck 3 ? deck 1 volume : deck 4 volume (do the same for eq_low, eq_mid etc)
Also keep in mind that the SZ is actually a real-hardware mixer, meaning that the audio routing is done internally. So you will also need to change the audio channel routing from the ASIO SZ Utility and send different Ch to USB chs
geposted Tue 09 Dec 14 @ 10:54 am
