Hello, I have a random bug issue, sometimes when I connect the microphone to a deck, then I have lag on the scratch response on my stantons SCS1d decks, mac osx 10.7.5, I use a keyboard key ALT+3 with script " deck 3 linein 'mic' " and when I turn off I always get a message "Error on Deck 3"
sometimes the lag happens sometimes it doesnt, if it does, I just re-start vdj8, using the script reinit_controllers does not fix the lag,I always have to restart vdj8
geposted Fri 12 Dec 14 @ 10:45 am
hello, I have found a way to force this random "lag bug" (does not happen everytime) so I have did a script to run on ONINIT : "deck 3 linein 'mic' & deck 3 linein 'mic' " so this way it turns on/off deck mic right on startup, btw VDJ8 also startup auto after boot, when it does happen I can't find a way to workaround it tried tweaking latency up/down, I always have to res-start vdj8.
thank you
thank you
geposted Tue 30 Dec 14 @ 4:38 am
