A Man and His Music wrote :
Do you have any of these songs in any playlist?
It doesn't matter if they are or not. Some songs that have never been on a playlist are duplicated, some are not. Some songs that HAVE been on a playlist are duplicated, some are not.
geposted Mon 05 Jan 15 @ 4:15 pm
Some are, some aren't. Songs that have never been in a playlist are duped, some are. Some songs that are in playlists are duped, some aren't.
geposted Mon 05 Jan 15 @ 8:42 pm
Can anyone help out with this, please?
geposted Wed 07 Jan 15 @ 1:40 pm
I sent you a private message earlier, but didn't get your database.xml yet to have a look.
geposted Wed 07 Jan 15 @ 10:41 pm
Didn't see the message - zipped and sent, thanks!
geposted Thu 08 Jan 15 @ 4:42 am
Ok, at first sight there is no problem with the database itself, it does not contain duplicates.
One of the songs in your first screenshot was Karaoke/SF Sunfly/SFA-SFD/Bananarama - Venus (SFD8013-10).zip
Could you try browsing to Karaoke/SF Sunfly/SFA-SFD and see if it still shows up twice.
Perhaps the problem is only appearing when using recurse?
geposted Thu 08 Jan 15 @ 6:25 am
I think I may have found the problem.
It probably only occurred for zip files, and you probably have zip in your fileFormats option.
By default it is not listed there since it is handled by the showZipKaraoke option already.
geposted Thu 08 Jan 15 @ 10:05 am
And I think you led me to the problem/solution!
I went into Options and typed ZIP in the Search field. 3 options came up:
fileFormats
getTagFromZip
showZipKaraoke
I remembered that, while diagnosing another bug, I added "zip" to the fileFormats field. I took "zip" out and voila, the duplicates went away! So apparently you can cause a duplicate of every .zip file to show up by adding "zip" to the fileFormats field.
(The previous bug was where .zip files dragged in from the Finder wouldn't show video - all other formats worked, so we tried adding "zip" there to see if that would fix it. It didn't, but it caused my .zip files to be duplicated).
Thanks!
geposted Thu 08 Jan 15 @ 1:11 pm
Hello everyone,
I have the same problem, but on my machine it happens with mkv-video-files.
Get 2 or 3 entries for the same mkv-files.
Any idea ?
System: Windows 7-PC
Built: 2177
Greetings
Ragman
Any idea ?
Built: 2177
Greetings
Ragman
geposted Thu 19 Mar 15 @ 3:10 am
I found some mp4-Files with double entries, too
Now Build 2179
Now Build 2179
geposted Thu 19 Mar 15 @ 4:13 am
Just an FYI that after upgrading to VDJ 8 I'm seeing this same thing... some video files are showing up in the browser twice. Same exact file name and path. I'll keep looking into this to see if I can find out why.
geposted Tue 21 Mar 17 @ 11:36 pm
I had the same issue, not when searching in my music folder but when using the filter folders.
There I had duplicate entries.
I solved it by selecting all parent folders* with the same name and remove them from batch> remove from search DB.
To double check all duplicates are gone, you can use the filter folders to check.
Normally these filter folders should now be empty as you cleared your full database.
Afterwards I selected my parent folder again and added to database search batch>add search DB.
Now the duplicate are gone.
*I have all my music in "my music" folder but it is showing multiple times in Virtual DJ; under favorites, volumes, local music, ...
Over time, I would one not always the same "folder" so this caused VDJ to start showing duplicates.
geposted Thu 23 Jun 22 @ 3:25 pm
