Topic: another strange mac issue
ok where to start had a really strange fault last night, i'm using macbook pro with adj 19mxr mixer ok so i'm doing a karaoke show, video crossfader set to auto, and i'm dragging & dropping tracks from the automix panel for music between singers.
i had issues last night with the auto video crossfade not working and when i manually activate the transition it fails to work (transition lights up but does not fade), also noticed tracks in the auto mix panel were not being marked as played and removed from the list as they should have been, this was being caused by the audio crossfade on my mixer being off centre (i never use the crossfade and it's off on the mixer) more than halfway to left or right and it causes these issues, i only have this problem with the 19mxr mixer it works fine with the vms 4.1.
geposted Thu 18 Dec 14 @ 4:09 am
