Hi,
i have two Macbooks...one Pro and one Air
since VDJ 8 Beta testing, i use only the Macbook Pro... i have a problem with itunes database... i don´t see the new songs in my buyer list and if i make a new playlist in itunes, i don´t see this in vdj... so i make a new itunes database : user/Music/itunes_vdj/... this is the new database path with the new database... but here the same, vdj don´t updated this database.
with may NEW Macbook Air, i can change the playlist and VDJ updated it now...
what can I do to make it work on the other device
geposted Mon 22 Dec 14 @ 6:17 am
is there no workaround
geposted Sun 28 Dec 14 @ 2:36 pm
Check if the iTunes database file pointed to by VirtualDJ is the correct one.
Perhaps after updating iTunes it is now using a new database, but left the old one in place?
geposted Mon 29 Dec 14 @ 2:01 am
Yes, i´m sure! I maked a another database of itunes with another path... and i can change / switch between this two itunes database on the same Macbook
geposted Mon 29 Dec 14 @ 3:43 am
