On my Denon DN-MC6000 (the older one), while using VDJ 7, I was able to push and hold the browse button there in the middle of the controller, and it would pop up browser window in FULL SCREEN! This is GREAT to be able to read down further into what you are searching! Push and hold the browse button again and it goes right back to the play screen! IT's REALLY COOL! Soooo how do I do this in 8 ?? It's not working that way on 8 and I cannot find a setting to invoke that option... HELP!
geposted Sat 27 Dec 14 @ 7:34 pm
For some strange reason they ditched that feature 8, so it is no longer avaible.......
geposted Sun 28 Dec 14 @ 1:11 am
Try the browser skin, and map that key.
geposted Sun 28 Dec 14 @ 4:09 am
Yeah, that's a puzzler, why did they drop it?
geposted Sun 28 Dec 14 @ 4:12 am
I recall one of the staff said it was because there was no access to decks while the browser was full screen - plus "nobody used it" (according to them).
As mentioned, it's still possible to have a FSB, but it needs to be specifically written in the skin code, and the code to map it varies from skin to skin because there's no set command any more.
It's fairly easy to add to skins that don't have it.
geposted Sun 28 Dec 14 @ 5:39 am
To all great responses to my delima... thank you! BUT see below!
Senior Moderator
Quote old post Posted Sun 28 Dec 14 @ 4:09 am
locodog
locodog
Country: GB LE user
Member since 2013
Ok... new user here HOW DO I DO THAT! :-)
Quote old post Posted Sun 28 Dec 14 @ 4:12 am
For some strange reason they ditched that feature 8, so it is no longer available.......
Right!!!
groovindj
groovindj
Country: GB PRO Infinity
Member since 2007
RIGHT AGAIN!!! :-)
Quote old post Posted Sun 28 Dec 14 @ 5:39 am
ahhhh what do they know... I'm somebody... and I WANNA USE IT!
As above... NEW USER HERE!! How do I do that! :-) HELP... thx!
Senior Moderator
locodog
locodog
Country: GB LE user
Member since 2013
Right!!!
groovindj
groovindj
Member since 2007
RIGHT AGAIN!!! :-)
geposted Sun 28 Dec 14 @ 12:49 pm
geposted Mon 29 Dec 14 @ 3:53 am
....or simply search the VDJ 8 skin downloads for 'browser' and find a whole bunch of skins. :-)
http://www.virtualdj.com/plugins/index.html?category=skins&search=browser
geposted Mon 29 Dec 14 @ 5:41 am
