Topic: Issues with some zipped karaoke files
Sometimes a zipped karaoke file will be listed as music only in filter folders. I found that if I load the karaoke file once from it's folder, when I return to the filter folder, the file is flagged as karaoke. But sometimes the zip file won't even show up in its folder? I the tested to re-zip it, which worked in some occasion, and in another case the file didn't work properly until restarting Virtual DJ.
Any ideas/suggestions? Bug or feature? Database related?
geposted Wed 31 Dec 14 @ 4:42 am
