Hi,
with build 2117.901 I let automix play overnight. A detailed look to the history view showed serveral times time ranges from from about 00:XX to 07:XX and not a continous time from 22:00 to 07:XX in the morning. The history file is has all right times, so this is just an display issue.
This sceenshot tell nothing, where/how to upload the history file?
Thank you.
Sascha
Thank you.
Sascha
geposted Tue 06 Jan 15 @ 1:03 am
okay I understand now the bug:
#EXTVDJ:<time>06:33</time><lastplaytime>1420522278</lastplaytime><filesize>7155719</filesize>
VDJ do not use the "time" tag. They use the "lastplaytime" tag for displaying. This result in groups of times as mention before, because the overnight playlist has about 40 tracks that repeated. If "lastdisplaytime" is used, it is clear that every same title in the history playlist has the same "play time".
Is there maybe already a fix available? I hope that can be easy fixed if not.
If there are further questions...I am here.
Thanks
Sascha
Thanks
Sascha
geposted Tue 06 Jan 15 @ 2:30 am
I can confirm that this issue is fixed in buil 2126.906.
Thank you.
Sascha
Thank you.
Sascha
geposted Thu 15 Jan 15 @ 10:36 am
