At the moment of opening POI Editor, vertical green line moves on the point actually played on the deck.
Once I drag and move the POI to a new position using the green vertical line (Play marker), how can the green vertical line come back to the playing point on the deck?
I'd like to do by means without closing POI editor and reopening it.
geposted Wed 07 Jan 15 @ 6:31 am
Hi twaga,
I'm not sure why you want this or what you do with it, but the only way I know is to pause the track briefly then hit play again
geposted Wed 07 Jan 15 @ 7:22 am
I feel that use of color on POI editor's waveform is more easily understandable for me to distinguish mix points than the waveform by one color on the active deck.
geposted Sun 11 Jan 15 @ 10:22 pm
Oh, sorry.
I've just found coloredWaveforms in config.
geposted Sun 11 Jan 15 @ 10:26 pm
