Forum: VirtualDJ Skins
Topic: [NEW] V8 Skin - OrangeJuice - Page: 1
@mods: i forgot the skinname in threat title. Can you please add "OrangeJuice"?
i saw the skin "Controller by DennYo" and loved it ;-)
started as an study project for my own use, i began to change buttons and visuals. The skin got a litte bit 3d and walk away from its flat look.
I wrote many parts of the code new in <defines> and shrunk the script.
i went back from the traditional color design like red/blue and use those colors only in a few parts (Deckname or waveform colors)
Beside the new gfx, there are many new features added:
- new Topzone with prelisten & sandbox inside, to create space for a bigger browserzone
- new setup inside the topzone
- seems to be the first skinrelease with a permanent waitlist / playlist.
Please aktivate "showHorizontalSideList" and read the readme.pdf inside the zip for config the 2nd Browser for use as an waitlist / Playlist
- new Waveform "2 in one row" show both waveforms side by side with overlapping beatgrids
- you can now toggle between 3 x FX Mode and 1x Fx Mode
- you can switch the cue list with a stored loop list in 2 layers 1-4 & 5-8
- move cbg with <-> near the wheel
- some new center panels for control Automixmode and Samplermode
i ask DennYo aka Denny F.. He gave me the permission to publish this skin
Screenshots:
permanent waitlist / playlist as you like
Center Panel "SAMPLER"
Center Panel "Automix"
New 1-Row - Waveforms side by side with overlapping BeatGrid
geposted Wed 07 Jan 15 @ 7:58 am
DennYO gave the permission to publish this skin (sorry, its german....)
geposted Wed 07 Jan 15 @ 8:20 am
love what you did to the AM panel .... nice ... very inspiring.
geposted Wed 07 Jan 15 @ 10:09 am
that was my intention....together as the first release with more than one Browser. Hope to get so some new, undocumented Info from other skinner / Atomix
geposted Wed 07 Jan 15 @ 10:16 am
Very nice, I like ;o)
geposted Wed 07 Jan 15 @ 4:24 pm
Can the wave be hidden??
Never understood the need for these full screen waves, other then that it look good.
geposted Thu 08 Jan 15 @ 6:05 pm
yes, one option is to hide the waves (similar to the original skin by DannYo)
geposted Thu 08 Jan 15 @ 6:20 pm
its not available yet..
please let us know when !
geposted Fri 09 Jan 15 @ 4:57 am
status: pending...... sorry
geposted Fri 09 Jan 15 @ 7:14 am
update:
i need some "testing" help
i just found out, that my included Waitlist is not correct in every case of your native screen resolution.
In my Beta are 3 new variants:
1. SafeMode:
original browser
+ fits all
- has this very big header....
2. Variant with right Sidelist/Automix;
built your waitlist with the Sidelist/Automixlist on right side of Browser
+ has its own column header and individial columns
- litte bit smaller as 3. because of the separate Column header
3. Variante with horizontal Sidelist as waitlist
- Option "showHorizontalSideList" must be manual set to 'yes' (action settings 'showHorizontalSideList' yes does not work...maybe a bug)
- no individual columns & header. Use the same column as the 2nd Browser "song" section
+ 1-2 more rows as 2.
my problem:
It could be (2. and 3.) that the Waitlist will not be drawed at correct place. It has to be moved a few pixel.
For this case a scripted a few variants -9 / -6 / - 3 to +9px.
it would be fine, if someone loads the Skin, activate both waitlists an tell me, if one of these variants could solve the problem and offer a correct waitlist. I only has a native 1600x1050 screen. This works perfect.
please leave a message here or per mail to info (at) dj-nice.net
you will get a dropbox link or the skin.xml per mail
thanks,
Alex
geposted Sat 10 Jan 15 @ 11:27 am
djnice :o) wrote :
action settings 'showHorizontalSideList' yes does nor work...maybe a bug
The horizontal sidelist doesn't show until you restart VDJ (when you change it in config) so a button with the action would be the same - require restarting.
geposted Sat 10 Jan 15 @ 11:40 am
mmmh...... i think, i did a test right as you wrote..... I will try it. maybe there was a syntax mistake
geposted Sat 10 Jan 15 @ 12:02 pm
is was a syntax problem.......in settings.xml stands yes/no but as an action you have to take on/off
It work now.
New Version 2.4 in Dropbox
geposted Wed 14 Jan 15 @ 5:26 pm
where I can download the skin?
geposted Wed 14 Jan 15 @ 6:50 pm
As mentioned earlier in the thread, send dj nice a message.
The skin hasn't been approved for download by Atomix yet.
geposted Thu 15 Jan 15 @ 8:38 am
geposted Thu 15 Jan 15 @ 8:57 am
As djnice said before, there is a problem with the middle browser - it is too wide for the screen.
It looks as if djnice has deliberately made the browser too wide in order to hide some of the tabs.
djnice, if you wanted to have only the sideview in the top browser area, you could use <sideview> to show just that part (see picture).
Also, right clicking the browser button for "middle browser on/off" doesn't work when the waveform is off.
geposted Thu 15 Jan 15 @ 9:33 am
thanks!
@groovindj
correct Folders & info should be nearly hidden
groovindj wrote :
djnice, if you wanted to have only the sideview in the top browser area, you could use <sideview> to show just that part.
interesting.....but i found nothing about it in the SDK. Did you know the correct way to use it?
i forgot ;-)
geposted Thu 15 Jan 15 @ 9:49 am
Complain to djtouchdan about that! You can just use sideview instead of browser - result shown in picture.
So the code for that section is now:
<sideview>
<pos x="+0" y="+0"/>
<size width="1366" height="160"/>
</sideview>
geposted Thu 15 Jan 15 @ 10:03 am
the <SideView> parts just uses a very oversized header/footer. Seems to be 1/3 of my upper browser space.
The are only 6,25 rows in playlist left. With an overlapping (bus causes also scaling problems) of the footer i will get 8,5 rows.
My variant offers 12 rows in playlist!
<sideview> variant @1050p
my variant @1050p
geposted Thu 15 Jan 15 @ 11:18 am
32%
