Topic: Mapping bug (Pioneer DDJ SP1)...........
Ok switch to a four deck skin and select deck 4 on the SP1. Now turn the loop encoder to your desired loop size and press the encoder down. Youll see it activates the loop on deck 1 when it should be deck 4 that the loop is activated on!!.
Can we get this fixed in a future build please??
geposted Wed 07 Jan 15 @ 8:24 am
Fixed in builds ending at .902 or higher
geposted Wed 07 Jan 15 @ 2:51 pm
Thank you sir 👌
geposted Wed 07 Jan 15 @ 3:42 pm
