locodog wrote :
Onint is keyboard/HW mapping, essentially you want to set all the skin vars to what you want (by usual methods) and then look at the var_list (script for this is "var_list") then whatever the persistent vars are (prefixed with a "@") you want to set them via the onint script "set '@var' X & etc etc"
Or you could, you know, just keep a back up of settings xml cos it's way easier...
100's of thousands spent creating an anti-gravity pen, or use a pencil
I did actually have a backup from September 2014 and so when I tried to overwrite the existing one with the backup, the behavior is still the same -- no cover on the Jogwheels. I even deleted the settings.xml file altogether and re-installed the program with a completely fresh XML and it still has the same problem. There must be another file its looking at because otherwise the problem would have been fixed.
geposted Mon 12 Jan 15 @ 7:58 am
Try substituting your variables with mine:
$HCMode=1818584692=0.00000, $JogCover=0=1.00000, $coverview=0=0.00000, $video=0=0.00000, $panel2=3=0.00000, $panel1=1=0.00000, $gridlines=0=1.00000, $decks=0=1.00000, $skincolor=0=2.00000
They may not all apply to silversleek, but when I run silversleek I do get the cover art.
geposted Mon 12 Jan 15 @ 8:10 am
You are a complete genius! It worked, however, how would I fix this for the other couple skins which also show cover on Jogwheel? Like what you've done for yours?
geposted Mon 12 Jan 15 @ 8:19 am
Actually you've fixed the problem altogether my friend -- all the skins that have the option to show cover art on the Jogs are now working. Thanks so much man for your help -- you are awesome. Keep up the great work on the Skins by the way -- SilverSleek rocks.
geposted Mon 12 Jan 15 @ 8:37 am
The other skins may also write similar variables to settings.xml when those options are chosen in the skin, so you'll have to load each skin and set the options so those $variables will be written to settings.xml from each skin. Because of this bug that wipes the variables, once you've got all your skins set the way you want, back up settings.xml or just make a note somewhere of everything on that particular line of the settings.xml so you can put it back manually if necessary.
I can't give you the parameters because I don't know which skins you're using, or what the variables are for each one.
I didn't write SilverSleek!
geposted Mon 12 Jan 15 @ 8:38 am
Sorry I meant to forward that last comment to Phantom DJ but as for this bug, I noticed that every time I exit the program and re-enter it, the same problem exists. To fix it, I go into SilverSleek and set the Jog Option to show Cover and then go to another skin and it works. I hope they fix this bug... Thanks for all your help -- truly appreciate it.
geposted Mon 12 Jan 15 @ 8:47 am
groovindj wrote :
+1 from me. Updates wiping stored globalvariables from settings.xml is very annoying.
kradcliffe wrote :
When is this bug getting fixed George
+1 stills here, each new buid.
geposted Tue 13 Jan 15 @ 1:02 pm
