Forum: Old versions
Topic: Automix Issues in VDJ 7
I'm using Virtual DJ 7 Home and something definitely seems different with my Automix from the last time I used the program. I have it set to Fade (remove intro/outro) 8 seconds.
Basically the problem is that when the next song starts up it sounds like it's jumping right into it rather than fading. The song fading out sounds fine, but the one fading in sounds off.
I'm fairly new to the program, but it has randomly changed settings on me before. What can I do to revert it back to the way I like it?
geposted Mon 12 Jan 15 @ 3:51 pm
did you tried some other automix types ?
Maybe the present one does not fit your needs ...
But it fit my needs last time I used the program.
I think "Jog Sensitivity" in the Settings is what I was looking for.
I have no clue why this program is constantly altering my settings.
Please make sure that you launch VirtualDJ as Admin.
