Forum: Old versions
Topic: Laptop freezes when selecting songs from folders.
bel1477Home userMember since 2011
Got a problem with VDJ, when selecting a song from files on my Ext Hard Drive. Whilst selecting the songs, the programme will freeze, on screen, for aprox 20 to 30 seconds, enabling any controls to be operated. However, the music still continues to play in the background, while this is going on. I have a brand new Laptop, which is very fast, at selecting & loading songs, but the freezing can make things difficult, especially when i am nearing the end of a song. Has anybody experienced this? and can anyone advise on this problem? Cheers, BL.
geposted Tue 13 Jan 15 @ 12:56 pm
RobRoyPRO InfinitySenior staffMember since 2012
Hi,
did you turned off USB EnergySaving in Windows Control Panel ?
geposted Tue 13 Jan 15 @ 1:11 pm
No I haven't turned off or adjusted anything in Windows.
geposted Wed 21 Jan 15 @ 5:04 pm
Does this need to be turned off/ to solve the problem?
geposted Wed 21 Jan 15 @ 5:05 pm
You should try ...
If your external HD is in sleep mode it will take a couple of seconds to "wake up" and load the track.
some external HD´s have their own build-in power management ( so USB Powersaving settings do not affect the behaviour of the external drive) .
In this case you can use a freeware tool like http://nosleephd.codeplex.com/
geposted Thu 22 Jan 15 @ 1:00 am
Thanks for the info, i will try & post how i get on, as soon as !!!
geposted Wed 28 Jan 15 @ 5:56 pm
