Forum: Old versions
Topic: Moving from one computer to another.
First of all all my music files are on external hard drive.And ive previously used 7 though 8s what im using now. I have a lot of virtual folders and history which ive been told are located either in the virtual folder located in documents. Ive noticed on my system that i have a virtualdj folder on the laptop drive and also the external and im wondering which one is the one i want to use in backing up and moving?
Obviously there should only be one and the others likely a backup that ive forgotten about. I thought that the c drive would have the main one?
If the external or maindrive is the only one necessary can i delete the other once someone confirms which would be the right one?
geposted Wed 14 Jan 15 @ 12:49 pm
according to what i read in help the main folders should be on the external correct??
geposted Wed 14 Jan 15 @ 12:51 pm
Back them both up. Belt and braces.
geposted Wed 14 Jan 15 @ 1:04 pm
