Topic: PFFX stop Working
espepePRO InfinityMember since 2009
The locodog PFFX. Its no Working no more with this new the last update what its wrong this new updates are very bad fix few things and others stop workin
1- High cpu no less than 70
2-frezzeng too much
3-timecode its no correct the bpm is to steady
When the program will be ready whitout isues !!!!!!!!
geposted Thu 15 Jan 15 @ 1:06 am
RobRoyPRO InfinitySenior staffMember since 2012
geposted Thu 15 Jan 15 @ 1:19 am
I haven't used PFFX for a short time but it is still working here.
geposted Thu 15 Jan 15 @ 1:30 am
2-frezzeng too much
PFFX working fine here.
maybe you need to clean your pc/mac; re-install OS ; I had similar problems back on builds 2030 and a fresh OSX install solved my High CPU problems.
geposted Thu 15 Jan 15 @ 6:45 am
well now its back working good!!!!
geposted Thu 15 Jan 15 @ 9:02 pm
