Hi there, my fellow Disco Jockeys!
Recently i've downloaded the latest version of Virtual DJ. I was using VDJ 7.4 and now i switched to 8.0. My controller - Reloop Interface Edition 2 - was working perfectly with version 7.4, but it doesn't work in latest, 8.0 version. How can i make things work? In LogReport that VDJ 8 created my controller is listed as: Audio device found: name="Digital Jockey -IE2-" vid="0x0A4A" pid="0xAA06"
I read that Virtual Dj 8 requires Controller Definition in .XML format for each controller. Does it mean that I must build my .XML definition from the scratch?
Few parameters:
- serial number of the controller: G101201049B
- vid="0x0A4A" and pid="0xAA06"
- miditrace message: F0 7E 00 06 02 48 50 02 02 00 05 00 02 07 00 00 F7
Please help, my work depends on it!
Few parameters:
geposted Thu 15 Jan 15 @ 6:58 am
UPDATE: Problem was fixed in the VDJ 8.0.2094. I was using 8.0.2048. Problem solved, topic can be deleted. Thanks :)
geposted Thu 15 Jan 15 @ 7:24 am
