Some of my video transitions in vdj 8 don't work just goes blank screen. The transitions that don't work are
Boxes, Alpha EQ, Starburst, Twister & Waves. Am I missing some software for those to work? Do I need to do a direct x update?
Also on vdj7 I could delete the transitions I didn't like on vdj8 I can't has SBDJ made a plug in to select the transitions you want when using random video transition yet?
geposted Sat 24 Jan 15 @ 2:36 am
The fact that these transitions are made for the V7 Version Code only, may explain this issue. As far as i know ALL native/ build-in transition on V8 work flawless. For all issues on other transitions you should contact the User who build the plugin.
geposted Sat 24 Jan 15 @ 3:11 am
I just downloaded vdj8 I haven't added any transitions to it. When you download vdj8 does it automatically add transitions from the vdj 7 transition folder?
geposted Sat 24 Jan 15 @ 3:20 am
Great I have just deleted the ones not working so only have working ones now.
geposted Sat 24 Jan 15 @ 3:36 am
Good to hear ...
just watch out for new transitions for V8 here :
http://www.virtualdj.com/plugins/index.html?category=effects&search=video
geposted Sat 24 Jan 15 @ 3:41 am
SelectRVT for v8 will be available soon. PC version is done, just sorting Mac version
geposted Sat 24 Jan 15 @ 2:28 pm
