Topic: Playlists..save
AsTheDJPRO InfinityMember since 2008
Is there any way to save the auto mix playlist in the same order I put it in? like VDJ-7
geposted Tue 27 Jan 15 @ 7:09 pm
have you tried saving the playlist from the AM dropdown menu?
It works for me, every time I reload the list it loads in exactly the same order as I last saved it.
geposted Wed 28 Jan 15 @ 4:57 am
Yes that the only way I know how,if it work for you I will keep trying it off and on... thanks Dj
geposted Wed 28 Jan 15 @ 10:53 am
ur welcome, if you don't get it to work how you want it to, feel free to ask
all the best
ray
geposted Wed 28 Jan 15 @ 2:42 pm
