Topic: Build 2126: Update Failed
FLeX69PRO InfinityMember since 2006
Hello,
I tried for a couple days to update Build 2126 and each time it states "VirtualDj automatic update failed, ....try again?" I appreciate your assistance. Flex
geposted Thu 29 Jan 15 @ 4:43 am
ChreecePRO (OEM)Member since 2014
Check your processes and look if there is an instance of VirtualDJ8.EXE running. Force close it or REBOOT your PC.
geposted Thu 29 Jan 15 @ 5:27 am
I checked and VDJ8.exe isn't running.
geposted Thu 29 Jan 15 @ 7:51 am
geposted Thu 29 Jan 15 @ 7:52 am
oohyeahPRO InfinityMember since 2010
Hello, Im just using VDJ 8 for a week and so far its great. For the past days its been prompting me to update to latest version. After a few instances I finally clicked Yes button. Now when I run it, it prompts me (attached pic) do you want to use new version now. When I click Yes button, it just keeps looping on the same prompt and not launching VDJ8. If I click No it will launch VDJ8, but I'm not sure if its the updated one or not. How can I fix this? Please help! Thanks
geposted Thu 29 Jan 15 @ 10:06 am
BTW: I'm using macbook pro osx 10.9.5 4 Gig memory intel core duo. I also noticed now it crashes after loading and playing several songs one at a time. Im using 4 deck skin
geposted Thu 29 Jan 15 @ 11:18 am
My update faild in the same way... Under W8.1X64
I know, I can use the direct download.
geposted Thu 29 Jan 15 @ 11:38 am
geposted Thu 29 Jan 15 @ 3:58 pm
So I followed the link posted above and the manual build seem to have worked. So far I'm not getting the crash. The only problem now is the audio sounds crackling and it seems to fix it if I use the gain from my RMX controller but only for a little while. I have a gig next week and hopefully no more crashes. BTW great VDJ 8 version. I love it!
geposted Thu 29 Jan 15 @ 7:33 pm
GGCOMPRO InfinityMember since 2008
just to chime in:
had the same error on my internet test machine.
(my real audio station is offline, so i manually downloaded nyway..)
just a FYI
geposted Fri 30 Jan 15 @ 9:53 pm
geposted Tue 03 Feb 15 @ 4:18 am
No idea - has no issues here. Maybe a problem with the routing at your provider ?
geposted Tue 03 Feb 15 @ 3:26 pm
