I have no samples (like the siren or saxo, etc)
What am I doing wrong..
works no problem in VDJ 7
geposted Thu 29 Jan 15 @ 6:03 pm
Did you go for the full install option?
You are using a V8 skin?
geposted Thu 29 Jan 15 @ 6:08 pm
Yes and yes..
in the field (under options) for sampler it's blank
geposted Thu 29 Jan 15 @ 6:55 pm
here is a screen pic
geposted Thu 29 Jan 15 @ 7:02 pm
geposted Thu 29 Jan 15 @ 7:03 pm
That's not a V8 skin
geposted Thu 29 Jan 15 @ 7:23 pm
geposted Thu 29 Jan 15 @ 7:25 pm
that's what I get..
Have you tried other banks <arrows>?
geposted Thu 29 Jan 15 @ 7:28 pm
yes..
nothing shows up..
but I can drag the file to the players and they will play??
nothing shows up..
geposted Thu 29 Jan 15 @ 7:33 pm
The samples from version 7 dont show up as a bank in version 8. You will need to install VirtualDJ in order the Sampler Banks to be installed (created), or of course drag n drop files/samples and create new Banks of your own.
geposted Thu 29 Jan 15 @ 8:11 pm
You are Awesome..
I got it..
Thx
I got it..
Thx
geposted Thu 29 Jan 15 @ 10:16 pm
