Topic: virtual dj 8
djbillcPRO InfinityMember since 2009
just to let you no that the resent update for viertual dj 8 has a bug when you say yes to update after update is dun it crashes virtual dj 8 when you load a video is ok with just music but not video's
geposted Fri 30 Jan 15 @ 10:42 am
RobRoyPRO InfinitySenior staffMember since 2012
do you use public or beta build ?
Which OS ?
Have you made a post in the specific topic ?
geposted Fri 30 Jan 15 @ 10:53 am
os x yose mite
geposted Fri 30 Jan 15 @ 5:35 pm
