Topic: sync and beat grid
Hey on vdj7 the sync function was more accurate on beat match and on the grid with sonidero music salsa and texano, vdj8 if the beat mach is ok but the the grid so if you use sync button you will be in trouble beats are all over. Yes I do know how to beat mach so dont tell me learn it but is a fuction on the software and should be improved checked same music with vd7 and vd8 and 7 did a whole better job even on reading the bpm lots of songs have double bpm on vd8 i have to input manually please check into it thanks
geposted Mon 02 Feb 15 @ 11:28 am
Beat and grid do not match on vdj8 but on 7 they do
geposted Mon 02 Feb 15 @ 11:29 am
