Topic: database V7 to V8 conversion
grid alligment in V8 is realy not so precize as in V7. If you compare the same song. I suppose some guys a working hard on it.
What even worse is automatic cue transfer from V7 database to V8. The higher time the higher difference and my old cues are in V8 screen definitely out of grid. /The cues in V7 screen are of course perfectly matched./
I have tried mapp folloving : shift_all_cues-50ms , but it seems not working for me and more I need shift values as percentages. Difference is increased with spent time.
best regards
geposted Mon 02 Feb 15 @ 6:11 pm
