Since using vdj 8 pro, I have noticed that when you get notification to a new version is available, do you wish to use the new version.
If you click yes, your large side list that you created with the tracks you use a lot disappears and you have to start from scratch and build up your side list again.
This has happened to me every time I have upgraded to the latest version, I hope someone could help
geposted Tue 03 Feb 15 @ 2:33 pm
Hey Mike,
yes this happensto me as well sometimes, I found a workaround... save your playlists, or I think that there is an option somewhere to save sidelists, but I don't use it.
best thing is "belt and braces"
always save your playlists
regards
ray
regards
ray
geposted Tue 03 Feb 15 @ 3:02 pm
cheers m8
I have a had a look, and I can't find anything that gives you the option to save the side list
can anybody help with
much appreciated
much appreciated
geposted Fri 06 Feb 15 @ 1:34 pm
Greetz Mike
I think you're right about saving sidelists, I can't find it either ... but ... you could try setting a custom button to switch_sidelist_playlist and then save it as a playlist.
geposted Fri 06 Feb 15 @ 1:48 pm
I have the same problem... I just make sure I save anything I want to keep before I do the install.
geposted Fri 06 Feb 15 @ 2:20 pm
or install new builds manually.
geposted Fri 06 Feb 15 @ 3:18 pm
thanks guys
I will give this a try tonight when working (before anybody comes in)
will let you know
will let you know
geposted Sat 07 Feb 15 @ 7:13 am
Or you may find some skins that provide this feature too. Anyway, it could be interesting to directly save sidelists.
geposted Sun 08 Feb 15 @ 12:29 pm
