Topic: Sidelist clears after vdj update
Since using vdj 8 pro, I have noticed that when you get notification to a new version is available, do you wish to use the new version.
If you click yes, your large side list that you created with the tracks you use a lot disappears and you have to start from scratch and build up your side list again.
This has happened to me every time I have upgraded to the latest version, I hope someone could help
geposted Tue 03 Feb 15 @ 2:33 pm
Hey Mike,
yes this happensto me as well sometimes, I found a workaround... save your playlists, or I think that there is an option somewhere to save sidelists, but I don't use it.
best thing is "belt and braces"
always save your playlists
regards
ray
cheers m8
I have a had a look, and I can't find anything that gives you the option to save the side list
can anybody help with
much appreciated
Greetz Mike
I think you're right about saving sidelists, I can't find it either ... but ... you could try setting a custom button to switch_sidelist_playlist and then save it as a playlist.
I have the same problem... I just make sure I save anything I want to keep before I do the install.
or install new builds manually.
thanks guys
I will give this a try tonight when working (before anybody comes in)
will let you know
Or you may find some skins that provide this feature too. Anyway, it could be interesting to directly save sidelists.
