button behaviour Cues, is it working? I can't see a difference between any of the 3 options. 2144
geposted Tue 03 Feb 15 @ 11:49 pm
It depends. You need to set the action as "cue_button" on your button to work...
If you set it as "cue" or as "cue_stop" then you override the setting... ;)
geposted Fri 06 Feb 15 @ 1:53 am
